| Posted: May 28, 2020 2:56 am | ||||
Nice to see your final version!
Beautiful filter and good idea. |
| Posted: May 28, 2020 2:58 am | ||||
Yes, I like very much the idea and is cool and interesting.
Thanks to Ramlyn and emme that helped to make this filter possible I have suggested to things for this filter in the original thread that started this idea From my own point of view I think is better to use a lower amount than 100 of "numbers amount" to see them more clearly, I have seen that around 66 is a good value, although of course this depends on the output resolution and the source image used. |
| Posted: May 28, 2020 3:05 am | ||||
| Mehmet Sensoy |
Thank you once again Emme, Ramlyn, and Spaceray. I'm just trying to learn FF with curiosity and with your help ideas come to life. I think FF Community is one of the best for sharing and helping each other. Thank you.
| Posted: May 29, 2020 5:56 am | ||||
I have seen one image based on luminance that is made with different objects depending on the luminance, and then I remembered that you have already than this with numbers, so I will try to replace the numbers with images and see what happens
So I think that according to this, you could use 10 images, that would be shown depending of the luminance |
| Posted: February 15, 2022 5:25 pm | ||||
I was wrong that this could be possible directly because it is ONLY allowed to make black and white shapes with one color so I have replaced the numbers with geometric shapes I will see if modifying the filter could be used with full color images |
| Posted: February 24, 2022 3:02 pm | ||||
