This is very good and interesting tiling in spiral of a source image and is also good to see how it is built.
Although I would like that it could be a little more explained on how the settings work, and know more what the settings do, the only really clear and easy to understand is the number of tiles and twist amount
I mean that it seems that when using them it fast becomes very distorted and you have to be very careful when you change the values
For example for low values of twist amount and any number of tiles number it gets very much distorted
It seems that you need to have both twist amount and number of styles equivalent and have the slider one above the other to avoid distortions, so for example if Number of tiles is 15 the twist amount is recommended to be around 48 if you have both Tyle type and ring reflection unchecked
The first thing to know is that a swirl tile will be distorted in most cases. To get more of an idea how it works, uncheck Fix Curvature (or set Curvature Amount = 50).
Number of Tiles = number of pie shaped tiles.
Twist Amount / 10 = number of swirls from left to center.
Tile Type: unchecked Horizontal Swirl Tile, checked Vertical Swirl Tile.
Ring Reflection: checked creates a mirrored image along the swirl line, this also cuts the size of one tile in half.
Fix Curvature and Curvature Adjust allow you to adjust the radiating zoom amount. The distance between the swirls is adjusted.
Does this help?
Thanks very much for explaining it better and I will make some tests and tells you if I can be able to use it better with your instructions
