Islamic Geometric Tiling Pattern Generator - 12-way Rotate and Mirror, Square Tiling With Full Line by Melissa Wiederrecht
http://www.filterforge.com/filters/15292.html
WOW! Thi is really a great way to be able to do this kind of things in FF, well done, useful and interesting how it was done
I have been trying to make something like this in the past 5 years but have not benn able to find out and although this filter in itself is not exactly what I wanted, modifying it and adding some few additional components can be what I want as shown below
There are 3 filters about his topic, although for now I have only used this one here
This filter has a great potential and power to do other different things than the ones shown on the presets above as it can be used with more components
For example if you add an Intslider to the repeat node of the 3 color gradient component and configure it with for example a 15 value max you get some cool and interesting lines patterns as shown on screnshot below
This shown here is the default 1 value that is inside the original filter that gives just 1 line and looks not very interesting, but as shown above if this not good looking lines are repeated then you can get something more interesting
And this is with a value of repeat 5 and you can see that many of the lines pass through the center
I like much how the lines can be repeated with exact distance one between the other
Well you can also decide and be able to change the design of the lines always go through the center and so none of the lines are passing through the center by adding a checkbox component to the rotate node of the 3 color gradient and so it will be like this
And after configuring correctly the checkbox you can get the result of lines not going through the center if wanted, so this way you have two different options and alternative, as you may not always want that the lines are crossing in the center
So here you can see the difference that you can get using a repeat value of 15 and compared with and without center
Here is where lines pass through the center
Here the lines does NOT go throuh the center with a 15 repeat value, so you can compare both and see
Additionally as the lines seem to be very thin and can be shown pixelated and could show badly if wanted to export for print or a high resolution work, is good to add a line width option
Add a slide control to the Position 1 as shown and is very important to configure the remapper with the values shown on screenshot
So, now you can be able to get some high quality black lines that are not pixelated and good for high resolution
Here I have put a 2000 x 2000 image size and configured some settings as shown
Also the seamless tiling gives a good interesting result if wanted
Here is the same as above but without the center active
Here is another example on how complex it can get with 15 repeat value
I like much how the lines are being crossed and that you could now after fill some of the cells with different colors or different shades
Thanks really very much to Melissa for creating this and for the way this filter was created and that it opens a wide way to make many other possible things as the things I put above is just some possible variations, but there are a great potential to do do much more, for example add colors to the lines, or fill the shapes with colors or even photo bits
There is also other possible cool variation if you add the Image component to the color 2 of the 3 Gradient as it will paint all the lines with the source image given using the gradient given by the Line width value
Also will change much if you select Repeat 1 value as shown here
or you choose a value of Repeat 3
and changing Repeat to 8 and Line Width to zero
And here you can see how the colors of the original source image are multiplied and distributed on the result
I will see how it could be used in other cool ways and find other possible uses thanks to Mellissa for this
Melissa Wiederrecht
Wow, SpaceRay, you have really taken this in an interesting direction! I never ever imagined the filter would produce such interesting results. I'm glad you are having fun with it!
I might play with some of those additions you added as well smile:).
Want to thanks very much again to Melissa Wiederrecht for making this filter that showed me clearly how to use the Loops with multiple lines and now I have started a new project that is based on this filter that will allow to make multiple things
Also have made a new version that will bend and add curves to the lines
The Curved Lines are only available and shown if the Sides value is between 1 and 4
Islamic CURVED Geometric Tiling Pattern Generator - 12-way Rotate and Mirror, Square Tiling With Ful.ffxml
