Filters: 712
Glowing Hearts Texture FB by FB58
http://www.filterforge.com/filters/15274.html
Filters: 712
Hi. I saw that the shape of some hearts is cut away because the size of the particle for the bomber is too big. Maybe this is what you wanted to obtain.
Instead, in case you wanted a more complete shape, like this....
Filters: 712
...you should resize two of the particles.
You can see it in the example that I attach.
I added two Scale components. This is just a quick change. You can surely do better. smile;)
Glowing Hearts Texture FB Remake.ffxml
FB58
FB58
Ramlyn ...thnx. I saw the problem and your solution. I made my own solution. I shall upload the improvement, I credit you for the improvement.
Filters: 712
Great! Thank you!
By the way, nice filter. I like it. smile:D
