WOW!!! WOW!! Congratulations for the editors pick because you absolutely deserve it for creating such very complex, awesome, impressive and stunning work, it seems you have work a lot to create this following my idea that you have replicated and copied perfectly with great detail and it works very well
Could be possible to make this kind of crosshatch effect shown here?
Is really amazing amd jaw dropping to see how you have done the filter by hand assembling all the lines bits one by one carefully rotating each one so they just overlap the needed and that it creates the whole pattern, this just oozes awesomeness and expert knowledge of FF to know how to do it and have the time to do it
You surely deserve what I hav put in the Ramlyn 400 filters page
I know now that I would have never gussed how to do it myself, and that using bomber was not the way to do it, is MUCH more complex
Thanks a million for making it so well, for all the time taken, and really apreaciate it much, I admire much that you are able to do this in such good way
Wow! Insane construction smile:-D And very impressive positioning work in here.
(I'm amazed by how well the editor handles such an amount of components)
Filters: 712
SpaceRay, thank you so much for all your compliments.
Yes, it took a bit of time working on this filter, because I had to put everything in the right position. It is not as good as I wanted, but finally it looks ok.
When you have other ideas for filters, let me know. I will see what I can do. smile:D smile:D smile:D
Filters: 712
Thanks Sphinx! smile:) smile:) smile:)
"Insane construction" : Ha! Ha! smile:D smile:D smile:D
Filters: 712
Thanks to FF for the Editor's Pick!!!! smile:D smile:D
Sphinx. wrote:
Wow! Insane construction And very impressive positioning work in here.
Absolutely true, this is really an insane constructions to build the lines pattern in such amazing and carefully detailed way and need much work to carefully do it so well
Is really impressive and jawdroping to seee how this was built
Thanks very much, will let you know, and you surely are an expert solving and having a clearer and clever idea on how to do FF filters
I have just seen that in the top of FF Facebook, your filter appears in one of the featured stripes, and this is because you have done a really great work showing what FF can do with much patience, skill and knowledge
See below the "Versatile"
As I am here, I want to suggest also that as shown above here in the facebook example, it could be possible to change the color of the lines as they are now only black and white, and you could add
a color control to the color 1 in the start to Profile gradient for lines color
and another for Color 2 as the background of the lines
here is with blue and white
and blue lines and yellow background of lines
and not only that activating the allow images, you can include textures inside the lines too and be able to have something in a similar way to Jasper Johns famous crosshatch art
and so you can fill your carefully built lines crosshatch with textures
and this was done as a 2000x2000 image and the detail zoom to see better the textures inside the lines
This is a Dahlia flower with black background lines
And if you want you can load different images in both color controls and have a more different effect
and it can be also filled the background of the lines and have a plain color inside the lines as here
I have used the FF Ladybug as lines background and Black as lines color
Be aware that only a tiny of the central part (where the lines are in the Component) will be shown
and here is using 3 big yellow, red and blue stripes
Filters: 712
Nice! Ok, I will work on a new version. smile:)
Filters: 712
High usage rank!
Thanks for using this filter!!! smile:D smile:D smile:D
