This is very good , realistic and perfectly combined the holes together and with the good shadow, very good and well done
dactilardesign
Filters: 56
Thank you man. To be honest, it is not perfect. I was not able to copy the spacing between the circular holes (vertical is a larger than horizontal, should be equal).
"did you see that? but you knew that already because you are an advanced user"
dactilardesign
Filters: 56
*can be done with more work and less flexibility
24 unregistered users.
