| earthbound |
Geometry pattern factory by earthbound
http://www.filterforge.com/filters/14934.html ![]() You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut? |
| Posted: April 10, 2019 7:31 pm | ||
| earthbound |
I've published (at this writing) 71 additional user presets for this in a folder which you'll find an explanation of how to use, at a git repo over here.
CorvusCroax' brilliant filter that was the foundation of this is over here. You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut? |
| Posted: April 10, 2019 7:33 pm | ||
cool and interesting filter you have made in advanced "negative positive Space art" combinations
and thanks for the 71 additional presets, but I think that it would be even better if you put your filter saved with the 72 presets, here on the forum instead on the gitHub Search in goggle images for this "negative positive Space art" |
| Posted: April 22, 2019 10:52 pm | ||
| earthbound |
thx
It is simpler code management to use Filter Forge's setup for user presets, as explained at the README.md at the GitHub page I link to. This way I only update a user presets XML file, and don't manage two filters (the published and a custom one) which do the same thing. The user preset XML file for this filter (to be dropped into the "/My Presets" user folder of a Filter Forge install) is at my repo here. Go to that page and CTRL+S (or CMD+S) (save) it into that folder and it will give you all the presets. I will merge additional custom presets anyone creates into that on request. Attach your version of the same file here or in a pull request at my repo, and I'll use this bash script (in development) to help combine custom presets into one file and eliminate any resulting duplicate presets. Any time now I'll post an update with many more presets (I think it tops a hundred now).. You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut? |
| Posted: April 26, 2019 7:18 pm | ||
| earthbound |
102 user presets now.
| Posted: April 27, 2019 1:38 am | ||
| earthbound |
134 user presets.
Combination math for possible states of filter controls, assuming simplified High Pass Radius parameters (forcing steps of that in 4) : 4 * 4 * 3 * 4 * 3 * 3 * 2 * 8 * 8 * 10 * 4 * 20 = 176,947,200 possible variations. That doesn't factor that for some settings controls have no effect, so it could be a lot less than that. It's _a lot_ though, clearly. ![]() You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut? |
| Posted: April 28, 2019 4:46 pm | ||
| earthbound | ||
| earthbound |
A new update to the filter optionally selects the result and randomly colorizes it. The colorization clamps to darker, medium and bright color shades for the black, gray and white respectively, in keeping with an overall aesthetic similar to the grayscale.
I think if you open it in the filter editor and uncheck "remap" on the color controls, you can get the colors in any shade. You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut? |
| Posted: May 4, 2019 5:56 pm | ||
| earthbound |
I moved these to another repo. Here's the updated URL. (There are other filters and stuff there too)
| Posted: October 4, 2019 11:27 am | ||
