J.R. Link
I have Filter Forge 7 installed and registered on a computer. I also have a login on the Filter Forge website. When I attempt to download a filter from the Filter Library, all I get is that "Download Filter Forge to use this texture" message.
I thought you had access to the Filter Gallery with the licensing of Filter Forge 7.
What am I doing wrong?
Thanks
Weyoun7
Mardar
Graphics Junkie
Filters: 61
Hi J.R. Link, Filter Forge may be asking you to update version 7 with bug fixes and so on. Does your message ask you to update? If it does then click to update and after following the prompts you should be able to down load anything from the library. Give it a try and see if it works for you.
J.R. Link, did you click the "Open this filter in Filter Forge" button? What happens when you do that?
42 unregistered users.
