WOW!! I really love this very much, because I like much to shatter, cut and shred and image into bits, and this makes this in a very good and great way, with different options. Lovely and awesome results
This can have many possible uses with carefully selected images
Here is an Hibiscus double flower using preset 1
Like how you can customize to have different block sizes, so not all the fragments are the same and also is possible to have more dispersion of the blocks which is very good
Like much how you can make a deconstruction of the image in different variable parts in such a cool and interesting way
And as you can define the Block Size and Large block chance, if you make it smaller, the effect adapts more to the original shape of the image but deconstructing it in awesome tiny tiles
If you reduce the Size,Pixels slider you can also get some cool result with mirrored and reflected image result duplicated
Like much the 1 2 Rotation option to rotate the image inside each of the blocks and this gives much options and possibilities
And with all the same settings and modifying only the 1 2 Rotation value
using all the same settings as the last image above, and only changing the Size Pixels slider you can get this other cool and interesting thing
and here is another custom settings
and with big blocks randomly that I like much
This filter remembers me of the Cecil Touchon Typography artworks where the originals are made from isolated letters and then it is cut into tiles and mixed them
You can see them here in this Google images search Cecil Touchon Typography
And there is also this blog
Cecil Touchon Blog art
The original source image for the Hibiscus flower examples is taken from here
saatchi art
Thanks SpaceRay! smile:D Excellent examples. You can also look to see how I use the Randomizer with the filter inside the groups.
38 unregistered users.
