Wow, nice one! I'd assign some of the finer-grained variations as a default preset.
I'm not sure why do you need a HighPass before Blur -- this slows the rendering and has no visible purpose. Also, the Surface Height was too big, this would result in bad normal maps. Here, I've modified the filter a bit:
Textiler VG.ffxml
Ludek Matousek
1. Thak you smile:)
2. I try remove a HighPass before blur and look for this change. I still learn work wit this software now .. smile:-) But ist very good .. smile:-)
There's still room for Distortion, Distortion Roughness and Distortion Scale controls on the filter settings tab... smile;)
very impressive!
i would think you could also do chain armor using that. just go a bit wider on the weave.
36 unregistered users.
