Abstract Explorer by CFandM
http://filterforge.com/filters/14570.html ![]() Math meets art meets psychedelia. |
| Posted: February 3, 2018 10:52 pm | ||
A fun filter to play with. I like your abstract filters. Since the email link doesn't work, I'll let you know that setting Zoom to 0 crashes FF7 on the Mac. Not sure if this an issue with your filter or with Filter Forge 7.
| Posted: February 3, 2018 10:55 pm | ||
Thanks Rachel, yep it was a fun one to make as well.....Yep crashes on windows as well so I checked into it......It is the bomber+ and the scale component together.....I will post about it in the bug thread.....So in the mean time I will check other scales and update with an older scale version if there is no crash....
UPDATE.....Other scales and bomber+ have the same outcome so those using this filter do not put the scale at zero... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: February 3, 2018 11:10 pm | ||
| Posted: February 4, 2018 11:12 pm | ||
If you want to post it then go ahead post away....I will take a peek and update the filter with the fix...
| Posted: February 5, 2018 9:50 am | ||
Okay, here is a fix for the Zoom=0 issue. Any values near 0 (+ or -) are set to a very low value to prevent crashes. If you want to tweak the values I picked, make sure to test both manual zoom entry and the value control, which seems more sensitive to crashing.
Abstract Explorer temp fix.ffxml Math meets art meets psychedelia. |
| Posted: February 5, 2018 5:50 pm | ||
Nice fix thanks....Seems that the scale will be fixed in the next parogram update thou....Click Here
| Posted: February 6, 2018 1:38 pm | ||
Scale/Zoom has been fixed in the latest FF update...This one no longer crashes...
| Posted: February 15, 2018 12:51 pm | ||
Wow! I had missed this beauty, amazing filter and artistic where you can explore multiple great and beautiful abstract complex colorful compositions
| Posted: May 7, 2022 12:19 am | ||
Thanks Spaceray. It also works along with other filters applied where some cool results can be accomplished.
This one uses Brush Engine Van Gogh and Standard Frames ![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: May 15, 2022 8:05 pm | ||
24 unregistered users.
