WOW!! Excellent and awesome geometric designs with the added balls, really cool and original and shows what FF can do
congratulations for your original and cool creations that you are able to make and for sharing them with us
Filters: 710
Thank you! smile:D smile:D smile:D
Many times I did filters that generated image effects.
They are very impressive at a first glance, but, at the end, the final result depends on the image. If the image, for some reason (too complex, not enough colorful, too small, etc.) is not fitting, the result is not nice as in the examples.
Then I thought to do more things that were independent from the image. They may sometimes be less impressive, but the result is clearer and they may also be easier to use.
I still think as said above that this really excellent and awesome, creative and well built in such great way
Yes, I agree that these are good thing and make independent custom shapes in the unique and special way you have the awesome skills and ability to make
and although it may be less impressive, what is important is not what you see, is what you can do you with creativity and how you can use this together with other things
Also this "simple" things could be maybe used as source shapes for other filters, I have just thought after seeing the presets that maybe it could be possible to use them in multiple variations with bomber and make a grid or random collage with many of these beauties
Filters: 710
Thank you! smile:D
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
14 unregistered users.
