LyricsGirl
LyricsGirl
Flower Petal Maker by Stage Light
http://www.filterforge.com/filters/14538.html
Music is Universal! Be Kind to your fellow animals and humans!
LyricsGirl
LyricsGirl
Latest New Filter- soooo I played around to see if I could come up with Leaves from the same filter...
PayPaul
PayPaul
I created a lucky charm with this filter. I was shocked that it worked.
Don't step on a dead dogma. It'll turn up again and bite you!
LyricsGirl
LyricsGirl
Now THAT is Lucky! Let's see what else we can come up with! smile;)
EAdams
I just tried using this filter from within Photoshop CC (using FF 7 as a plugin), and although the preview in FF looked right, once I applied the filter and returned to Photoshop, the petals were gone. Instead, I get a white hole in the middle, and the rest of the entire layer is filled with the solid color of the preset. The texture is there, however. The image is 2421x2421 pixels in size.
Any idea what is wrong?
LyricsGirl
LyricsGirl
Hi EAdams.I cannot help.I didn't create the filter and I do not use PS.I use Affinity.Can you go to the filter and note down the settings these are the second tab. It may be something totally different but if I can re create it in my software then we know it is the filter settings. does the filter work OK with the pre set filters?
EAdams
I only tried 2 of the presets and didn't change any settings. In the meantime, I can't even search for a filter containing the word "flower" in FF7. I am going to post the issue in the appropriate forum. smile:)
