Watercolor Eye by Ramlyn
http://www.filterforge.com/filters/14461.html
I kinda like this look actually. Maybe you could add an adjustment control on the *amount of* blur/watercolor effect ? Make it more versatile. smile:)
Filters: 712
Thanks jffe.
Yes, I will do an update. It can be a good idea. smile:D smile:D smile:D
Filters: 712
Done! I posted an update with 4 new controls.
This is how it works :
- The result is blended again with the main image, using a normal blend.
The amount of the blend is controlled using Watercolor Amount.
- The image can be blended with the result as it is, or modified using Median and Noise Distortion. This allows to create a wider variety of effects.
B Median, B Distortion and B Distortion scale are the controls used to do it.
