The Nana Labyrinth by Ramlyn
http://filterforge.com/filters/14464.html
Oh hey this is cool!
Filters: 712
Thanks Skybase!!! smile:D smile:D smile:D
I was in Bangkok when I made it. That day I walked through some intricate streets and it gave me the idea to try doing something similar. smile:D
PayPaul
PayPaul
Thanks Skybase. I did figure out a way to add colors to it by adding color controls to the high and low nodes of the threshold component. A learning experience.
Don't step on a dead dogma. It'll turn up again and bite you!
Filters: 712
Nice result PayPaul. smile:D
If you need help with this filter, let me know. smile;)
PayPaul
PayPaul
I did allow for images in the color components, but they only really work when certain types of images are used. Feel free to submit an upgrade to this filter using my edit. I wouldn't even presume to post it as my own. I was looking for the way to add colors to your originally black and white results. I stumbled a little but discovered the correct place to connect the color components by tracing the results back to where the black and white first appears. I'm quite happy to have figured it out.
Filters: 712
He! He! Yes, it is nice to understand how the filters work. I also always look into other people filters, trying to add some specific thing that I want to do. smile:D smile:D
Filters: 712
Editor's Pick! smile:D smile:D smile:D
Thanks Filter Forge! smile:D
Insta-maze ! smile:D
Filters: 712
He! He! Thanks jffe! smile;) smile:D
Filters: 712
PayPaul. I added the chance to have colors. smile;) smile:D
This way, also with the original filter, it will be possible to get colored results.
The colors are added in the Threshold component. Maybe it is the same location where you also added. smile:)
PayPaul
PayPaul
Yes, it is the same location. It's the only place I discovered it was possible. Do that in any early stages and the threshold component will cancel out the added coloration.
Great and very good, well done, cool.
jffe wrote:
Insta-maze
I thing is Amazething
Filters: 712
Ha! Ha! Thanks SpaceRay!! smile:D smile:D smile:D
Filters: 712
High Usage Ranking! Thanks to everybody for using my filter! smile:D smile:D smile:D
