Nice ideas, but the colors inside the sphere are somewhat dull. Take a look at the techniques we used for creating glow in these filters:
http://www.filterforge.com/filters/237.html
http://www.filterforge.com/filters/286.html
http://www.filterforge.com/filters/285.html
NickyTannock
I’m planning on fixing that by the time I’ve finished version 4 of my filter.
At the moment I’m trying to figure out how to transform my sphere into a funnel. I’ve been using this link as a reference. http://leminuteur.free.fr/picsvortex.htm
I’ve uploaded this filter while in mid development between versions 2 and 3, much earlier than I originally intended. In version 2 I created an animation timeline for my filter, the result of this can be viewed here in a 4 second clip http://www.youtube.com/watch?v=Ptm0trFZeaQ
voldemort
voldemort
Filters: 649
Take a look at my perspective and pinch snippets they will show you how to create a funnel effect you could even add a swril based off any of the swirl techniques to really make it pop
http://www.filterforge.com/filters/1892.html
http://www.filterforge.com/filters/763.html
http://www.filterforge.com/filters/1898.html
http://www.filterforge.com/filters/1926.html
http://www.filterforge.com/filters/1927.html
http://www.filterforge.com/filters/1946.html
http://www.filterforge.com/filters/2037.html
theese are some to help you get started
looks great more pressets would be nice though
Cool. If only I weren't such a lazy bastard, I'd be doing FF animations too! smile;)
Can I say 'Batch Render'... again... please... !!! smile:angel:
nice filter, michael. can you make the 'wormhole' larger and smaller or is it just this one size?
NickyTannock
I've been working on creating a controller for the wormhole size, but at the moment there seems to be some kind of fragmentation glitch in the mouth of the wormhole. And even though I’ve removed this control for now, this problem still pops up when you hit the “Next Variant” button.
ah, ok. thanks smile:)
voldemort
voldemort
Filters: 649
I had a similar problem recently with a filter I release That you couldnt hit next varient or it got messed up
I then recreated everytning in a nother one identical and it worked for awhile then stared doing the same thing if you manually moved the sliders you could go as crazy as you wanted and it worked fine but hit next varient and it got screwed up
Ill try to remember wich one it was --I added description of problem in filter description --maybe by comparing the two it can be tracked down
NickyTannock
I checked in the list of your submitted filters, is it this one that you’re talking about? http://www.filterforge.com/filters/2040.html
voldemort
voldemort
Filters: 649
Bingo I must appologize affter telling you I would check into it I forgot with the insanity of the day again sorry but yeah you found it exact same kind of annomoly
Torley
Second Lifer
Someone could make an effect similar to Stargate with this!
I'm enjoying using Filter Forge to create http://torley.com/textures
NickyTannock
Eventually yes, but right now it’s incomplete, and very limited.
In the future this filter will be able to make any wormhole you choose to imagine, I’m just hoping no one looses interest in it before I‘ve finished.
I'll be uploading version 2.4 soon.
"Sliders" is one of my favourites movies.
Thanks to the Author for this excellent work!
21 unregistered users.
