Erik Pedersen
Goggerfett
Expression Square 2 by CFandM
http://www.filterforge.com/filters/14336.html
The Joy is in The Work
Erik Pedersen
Goggerfett
Oh man, I love this - thanks so much for sharing! I can't wait to get home and play.
Glad you find it useful.. smile;) smile:)
You can also load an image (settings image) without a transparent background...Might have to play with the amount and spread of the image but there are more abstracts that result..This was a landscape image with dirt, grass and a sky...
nice, CF&M smile:)
Thanks Craig.. smile:)
Mardar
Graphics Junkie
Filters: 61
Haven't had time to play with this one yet, but it looks yummy from the presets. I really like the first version of this filter so I'm sure I'll like this one. Thanks my friend. smile;)
You are welcome Marlene. More inspiration from sitting in the doctors office staring at art on the wall.. smile:D
Cool, interesting, curious, artistic and well done, great
Congratulations for the EP
Thanks SR....For more fun render some images from some of the filters in the library and then use those for this filter.....I used Ronjonie Gold River 1 and rendered out some images...I then used those for some more abstract fun....Needed to try some gold... smile;) smile:)
Yet even more fun is thinking about the color scheme that you want for your abstract....Combining two filters together such as the filter above with Kochubeys Hipster Background I cut a little square out to have some gold around the middle.....First image is the two results combined then the second is the expression square.. smile;)
One More... smile:)
raabix
Nodist
Which gallery does sell these? smile:D
This is serious procedural art.
lol......Thanks rabbix thats what I was trying for.. smile;) smile:) ...
Other ways to bring more color to the abstract is take multi images and composite them together before loading them into this filter......Kinda like the above moethod.....I chose three images and combined them in one image below....
I then loaded the above image into the settings section of this filter and the result was more color and variations....
Then one more variation using the same composited image.....
Please, can you be so kind to explain how the filter takes or chooses the colors from the source base image ?
I want to be able to use more your wonderful and awesome filter, but I am sorry that I could not still understand how it works as I get weird results, that are good but not what expected or supossed to be, because I really do not know what to expect
I really love the very realistic and amazing brush paint strokes that are generated.
Thanks very much
Choose your image base in the settings section for the colors and then open the same image through the menus to keep the same size as the loaded image. It just looks better when doing this. You can edit the image and look at the section in the image below to see how the colors in the image are processed.
Thanks very much, now I understand and I was doing it wrong as was only loading main image from the menu BUT without using the same image in the settings so this is why I was getting It wrong, sorry
Here is a quick video of playing with this filter. I was using one image and getting different abstracts. Using Expression Square 2
When saving the image I usually set the AA to all pixels and 17 samples. Gives a nice smooth image in the finally rendered result.
You can find another sample HERE
Oh, sorry that I forgot to answer.
Thanks really very much for making the video and showing how to make it, much appreciated for taking the time to do it
I have remembered about this awesome and amazing filter and have thought that this is a generative excelent realistic brush strokes could be used in another possible way
I mean that it could be added an optional image that could be used as overlay of this awesome designs, and so it could modify optionally the final result and have a blend mode to choose what would be best depending on the overlay source image
Here below is a fast example I made, although could be done in a different way
You can enable or disable the overlay and when enabled, you can choose a blend mode. For this to happen the Background on first blend mode must be transparent with Alpha = 0 and the shown remapping
If you want I can upload the modified filter
