Chin Rey
Filters: 9
Smooth Tiling by Chris Goldthorpe
http://www.filterforge.com/filters/14130.html
Chin Rey
Filters: 9
This filter is amazing. I fed it an absolutely hopeless brick wall photo I had given up and got a very usable result right away. Not perfect of course, making a texture truly tileable and not jsut seamless will always take quite a bit of manual editing. But this filter can save so many work hours I think it alone is worth the cost of buying Filter Forge.
Chris Goldthorpe
Chris Goldthorpe
Thanks Chin Rey! I always have problems getting background images to tile nicely and decided it would be less work to write a filter than to do them by hand in Photoshop.
Haras Arch
Hara's Crown
Wow! This filter does amazing things with the circular patterns created from the mandala filters. I had been making beautiful things with especially jhantares' filters, but couldn't figure out how to make a repeat that would cover a rectangular area with them well until now.
Chris Goldthorpe
Chris Goldthorpe
Thanks Haras Arch! I wish there was an easy way to chain filters together because applying wild perspective to the results of Smooth Tiling produces some interesting results.
This looks cool and well done, will have to see how it works, from the well done presets, it looks very good and interesting
studebaker
Well done plugin, Chris. And remarkably useful. On your next update, could you please consider adding the ability to rotate the donor image as well? smile:)
Chris Goldthorpe
Chris Goldthorpe
Thanks studebaker. I wasn't planning on adding more filter controls because the filter is deliberately minimalistic. I had thought about adding shift and scale controls but I find that the more controls are added the harder it becomes to use them. If you are launching FF from Photoshop you can rotate the image there.
