Repeat and Recede using Mask by Chris Goldthorpe
http://www.filterforge.com/filters/13578.html
I had missed this filter, and it looks awesome and great from the default thumbnail
I have discovered it because it was featured on the FF facebook page
ff facebook article
It looks like it can give very good results mixing the source images in great ways multiplying in different and cool ways
Chris Goldthorpe
Chris Goldthorpe
Thanks SpaceRay! The thumbnail doesn't really indicate what the filter can do - the artwork I added to the gallery gives a better indication of how it can be used and what the before image looked like. It's different from most filters in that you would usually want to prep the image before applying the filter.
Well nearly 10 years after I have found again this filter that I think is really interesting, artistic and creative and using the right images it could be very good
This kind of filters is what makes filter forge shine and show the true and real power and potential available
I wanted to make it show back to any other new possible FF users to resurface it and show why Filter forge is different to any other software available that can let you do things like this here as it deserves to be seen again
Chris Goldthorpe wrote in the link above from facebook image shown : I used Photoshop to prepare the input file which used 6 separate photos of Roses taken in a rose garden. These were cut out and placed over a pure blue background. I used Repeat and Recede using Mask with the mask color set to the same pure blue to create the final result.
These roses are really well done composition and great collage and example off what can be done and looks great and is the same image that is in the FF gallery shown here below
I have found the image you are refering here
The Ultimate Rose Garden By Chris Goldthorpe
DO NOT MISS ALSO THESE OTHER FILTERS AVAILABLE
Repeat and Recede using Color Match By Chris Goldthorpe
Repeat, Recede and Animate By Chris Goldthorpe this includes animation
Linear Recession By Chris Goldthorpe
