PayPaul
PayPaul
Kaleidofractalscope by CFandM
http://www.filterforge.com/filters/14039.html
Don't step on a dead dogma. It'll turn up again and bite you!
PayPaul
PayPaul
I found out, much to my pleasure, that I was able to add an image component to it. I attached it to the Accumulated component that had "Initial" as an available connector. Of course the aspect ratio of most images do not allow seamless tiling but my addition does make for some interesting variations. This personal filter based on yours has given me another lesson in filter creation and/or modification.
Good to hear....I try to make some filters modifiable just for that reason.. smile:)
As far as aspect ratio there are many ways to mod the filter depending on the look that you want....Here is one quick example using the color control with "Allow Images" and a scale and offset...Use the offset to move the image and see what happens to the colors of your final tile.... smile;)
Then when in the main window of FF go to the menu at the top and choose "File" "New Image" and use a square size.....You will have a seamless tile with the colors of the image loaded via the settings "Color Control"...
I would get very dizzy very quickly if this was all over my floors and walls. smile;)
(I added a vignette)
smile:D For sure... smile:D
Cool.. smile:)
