jhantares
Filters: 272
Hexagonal Mandala Shaper by jhantares
http://www.filterforge.com/filters/14022.html
jhantares
Filters: 272
How to use this filter
This filter generates hexagonal mandalas using 5 different generators. A slice is cut out of the image. You can alter/transform the slice by sliders "IM" and "ND".
Use slider "Select Mandala Pat." to select mandala generator. Use sliders "Shadow..." to alter shadow width and bevel. Use sliders "BG" to alter background color and gradient.
Set "Mandala Pat." to 1
generates octagonal pattern
Set "Mandala Pat." to 2
generates triangle pattern
Set "Mandala Pat." to 3
generates nonagon pattern
Set "Mandala Pat." to 4
generates pentagon pattern
Set "Mandala Pat." to 5
generates hexagon mandala
I continue to like your beautiful and well done mandalas and kaleidoscopic filters that with the right source images can give great results, well done
