xirja
Idididoll Forcabbage
Modulo Fun by CFandM
http://www.filterforge.com/filters/13874.html
xirja
MMMModulooooooo smile:)
LexArt
LexArt
Like it, good idea, I think is FUNctional smile;) smile:)
smile:) lol..
This is neat, Chuck! You gave me some ideas, too.
Thanks Adam.. smile:) ....oooo I really like that bottom one...
This is weird how it works, and the patterns it can make, but will have to use it more to learn how it works by default
As it is supossed to be Fun, I have added some fun to it by attaching one spectrum component and 3 color controls and then added them to color 1 of the Profile gradients and get much weird results smile:D
but why stop there, instead of only having one image on each, you can also mix them using the color 2 of the profile gradient and get even weirder results smile:D
It seems that the first profile gradient is the most visible as shown here with the lifesaver that is seen at the top and the others are just behind
All these 3 are based on the preset 1 profile curve
And using some typographic art on second and third color controls
Also using preset 1
And using
Lifesaver as Color 1
Garlic as Color 2
Typographical Art as Color 3
Now is all the Color 1 and 2 filled in the Profile gradients
I like how the Gradients are able to cut and modify the original images to mix them later
Looks extreme Spaceray.
Interesting results SR......Looks of fun stuff can be created with the Modulo...Some may be of use if not fun... smile;)
A quick grid using Modulo with the Pixel XY on the advanced setting for the result component....
Quick Grid.ffxml
