jhantares
Filters: 272
MosPat Generator 30 by jhantares
http://www.filterforge.com/filters/13873.html
jhantares
Filters: 272
This filter generates patterns using 6 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GRx -> Color/Gradient controls
K1 -> Kaleidoscope component
Set "Select Generator" to 1
Use sliders: "G1", "G12", "G123456"
Set "Select Generator" to 2
Use sliders: "G2", "G12", "G123456"
Set "Select Generator" to 3
Use sliders: "GR3", "G34", "G123456"
Set "Select Generator" to 4
Use sliders: "G4", "G34", "G123456"
Set "Select Generator" to 5
Use sliders: "G5", "G123456"
Set "Select Generator" to 6
Use sliders: "G6", "G123456"
Check "Kal on" to use "K1" sliders.
