PayPaul
PayPaul
Gradient Extract by Martin Naumann
http://www.filterforge.com/filters/13815.html
Don't step on a dead dogma. It'll turn up again and bite you!
PayPaul
PayPaul
Ir gas potential as a handy tool. To makes these gradients work in Photoshop do I save the result as a Jpeg, a png or a TIFF file? How do I then save it in PS as a Gradient file?
Interesting work!
Filters: 712
Yes, good idea. It can be useful also to incorporate in other filters. smile:)
Martin Naumann
Martin Naumann
Filters: 98
thanks for the feedback!
btw @PayPaul i also thought about this but currently it's not possible i guess.
use color selection to analyse the colors of it and make your gradients manually
I have looked at the possibility of converting this gradient to a Photoshop .grd file. So far I have only seen manual solutions using the eyedropper to "recreate" the gradient. This is due to the difference between a rendered gradient and a .grd file, the gradient from this filter is continuous, whereas a gradient in Photoshop is a set of color and transparency stops.
It might be possible to create the .grd file with a lot of stops and get a similar result to a rendered gradient, but I have not seen a program or a method to do this. I'll keep looking.
17 unregistered users.
