| Posted: April 29, 2016 8:47 am | ||||||||
WOW!! Finally this is available! Who else would be able to make an awesome 3D cube like this than ThreeDee who is expert in this kind of things
Very good the image position on each side and the transparency Like it much and what is really surprising is that you can ROTATE it in 3D space!!! Congratulations for this amazing work |
| Posted: April 29, 2016 8:50 am | ||||||||
Very beautiful filter.
I like the effect of partial transparency: it gives even more 3D feeling. |
| Posted: April 29, 2016 1:02 pm | ||||||||
Gill Brooks
Posts: 54 |
| Posted: May 3, 2016 7:18 pm | ||||||||
I will try to see if I can modify this filter to have one image on each of the 6 sides
I have seen that the sides of the cube are all repeating the same image that is loaded through the file menu, so to change the built in image for your own, you have to go to: File--> Open image and choose your own Trying to discover how you have been able to put 2 images on the side of the cubes I have seen that you may have loaded an image into the Cube Face Color So there is also another alternative if you want to "unload" or remove the built in image You can go to the menu File --> New Image Choose the result size Click and select Fill color On the color picker go to the A slider (Below H S B) and put a zero value to make it transparent |
| Posted: May 4, 2016 12:49 am | ||||||||
Gill Brooks
Posts: 54 |
| Posted: May 4, 2016 5:28 am | ||||||||
The "cube face background" shows only when the main image has transparent sections in it. For instance, if you had transparency instead of the green clouds in the above image, you could use another image there. The filter is not all that developed. It mostly demonstrates the rotatable cube functionality. |
| Posted: May 4, 2016 8:06 am | ||||||||
Gill Brooks
Posts: 54 |
Still a good start though - far better than I could do
Gill |
| Posted: May 4, 2016 10:05 am | ||||||||
As ThreeDee said well, you have to load the image background on the Cube Face Background, and then a image with Transparent background around in the Cube Face color, see how the presets are done and it will be shown |
| Posted: May 4, 2016 2:48 pm | ||||||||
LexArt
Posts: 256 |
Very good and well done, like how you have done it and looks very well
| Posted: May 6, 2016 1:56 am | ||||||||
paulcopeland
Posts: 43 |
G'day ThreeDee, what an awesome filter. This is just what I need.
Now here's 'ThreeDee's challenge for the day Create a version so that the user can upload four images, one for each side of the cube! That will keep you busy for at least half an hour Best wishes and keep up the great work. Paul. ![]() Winner Jean Bogan Piano Composition Competition 2016
| Posted: May 31, 2016 12:44 am | ||||||||
LexArt
Posts: 256 |
Why only four images? It would be better if it was 6, one for each side of the cube, so you can freely rotate the cube and there would be always a different image on each side |
| Posted: June 1, 2016 1:58 am | ||||||||
| Posted: June 21, 2016 12:47 pm | ||||||||
LexArt
Posts: 256 |
nice work CFandM, like the menger sponger image, is it done in FF?
i have seen inside the filter if it could be changed for adding one image for each side, but I do not understand how it works, as all seems to be based on only one image and not prepared for multiple source images. |
| Posted: June 22, 2016 5:46 am | ||||||||
Yes it was done in FF.......Some new methods and very old methods..
| Posted: June 22, 2016 11:19 am | ||||||||
LexArt
Posts: 256 |
CFandM, Good that you can be able to make these good 3D complex shapes and with that good lighting too
| Posted: June 22, 2016 3:57 pm | ||||||||
Its all about the gradient..
| Posted: June 23, 2016 12:36 pm | ||||||||
WOW! This is very good and well done, this remembers me your other similar filter Sierpinsky City by CFandM but now is even better and more awesome, well done.
I have seen that there is no way to see 4 images at the same time, you will only see 3 images
Well I have been able to make a version that is able to use 3 different images (each one is copied to the opposing side) and will see if I can make it to have 6 different images. Will put the filter when I make it right. Also you will be able to make each border different if wanted here is an example |
| Posted: June 25, 2016 1:30 am | ||||||||
paulcopeland
Posts: 43 |
Impressive work here being doing by the Filteforge artists.
Looking forward to seeing and using the latest version. Winner Jean Bogan Piano Composition Competition 2016
| Posted: June 25, 2016 3:17 am | ||||||||
Thanks paulcopeland
here is below the filter with 3 images By the way, You may want perhaps also see this other 3 images cube that was done much time ago, although is not rotatable, but is able to be multiplied and have many cubes together 3D cube in Q*Bert style Is included also the filters on page 1 and 2 Image Cube 3 images.ffxml |
| Posted: June 25, 2016 9:11 am | ||||||||
Bump and since I am using Threedees filter for this experiment thought I would post it here...This is for FF6 beta.... Spong-e.ffxml Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: July 26, 2016 12:52 pm | ||||||||
After 8 years of this awesome and amazing unique and clever filter, and thanks to Rachel Duim remembering it to me here, I have thought than now that FF has animation, this cube could be finally be true and have real rotation and move
CAN THIS THREEDEE ROTATED CUBE BE ANIMATED? The answer is YES, it was not as easy as I thought to replace the rotation component, but after thinking about how the remapping was done, I tried to simulate it in some way with the normalized time component, and after some testing it finally WORKS and the dream of ThreeDee of having real rotating cubes is now possible in FF Studio and here below is the proof of it for you to try yourself the modified filter using the original one image filter from Threedee BUT NO 360 DEGREES ROTATION YET I have not being able to make it render a full 360 degree rotation, so I will have to make more tests, as increasing the frames does not increase the amount of rotation. Maybe the original filter was not made for making a full 360 degrees because was done for a FIXED image to be shown and was not needed. Will make another one with the modified version I made with multiple images Image Cube real rotation animated.ffxml |
| Posted: March 14, 2024 5:01 am | ||||||||
Very nice! |
| Posted: March 15, 2024 7:04 am | ||||||||
Is this the animation of 360 degrees you are looking for?
Image Cube y axis rotate animate Doesn't work properly in Safari. Math meets art meets psychedelia. |
| Posted: March 15, 2024 7:31 pm | ||||||||
YES!! It seems that this rotates 360° correctly, how you have done It ? I am sorry that I still I am learning how the procedural animation works ANIMATED ROTATION IN X AND Z AXIS? I wonder if It could also maybe be able to make It rotate also in X and Z Axis , It would be really great |
| Posted: March 17, 2024 6:23 am | ||||||||
First, the filter is fixed in X and Z, so no rotation in those axis.
All I did to the original filter is swap out the Rotation slider control with Normalized Time. I made sure the mapping to the 3 components it attaches have the same mappings as the original. The original filter does support full 360 degree rotation. I've attached it here in FF13. Image Cube y axis rotate animate.ffxml Math meets art meets psychedelia. |
| Posted: March 17, 2024 12:06 pm | ||||||||
