Grid Image Input by Rick Duim
http://filterforge.com/filters/13788.html
WOW! This is very good and well done. Awesome to have another of this filters and that the grid does not have to be square
Thanks very much for making it, and for including the alphabet grids examples
If you do not know what is all about, you can see where this all started, please, read this thread
Found a possible way to "batch" load multiple images in bomber plus
Specifically after my post number 8 and the awesome filters given by Skybase and ThreeDee
LexArt
LexArt
Thanks very much for making this filter and it may be very useful. Well done and clever solution
Although seeing the preset images may bring to wrong thinking about the real use of this filter, that is not about breaking a single source inmage in squares and shuffle them, although of course it could be used for that surely as alternative use,
I have tested it and works flawlessly and very fast.
here is one source image given by SpaceRay in the forum
LexArt
LexArt
And here is the result from this filter feeding this image above into the filter.
What is important is that you can increase very easily the amount of image tiles and they will be perfectly added and avoids much to repeat the same tile from the source grid, and is very varied.
And you very easily have thousand of variations very fast and with the amounts of tiles that you may want.
Here is the result
LexArt
LexArt
And modifying the bomber settings you can get much more variations and results
LexArt
LexArt
with more tiles
lol I always enjoy the fact that K is missing from the source input because a 5x5 doesn't fit 26 letters.
Thanks Lexart for putting this examples, they look good and well done, and shows what it really can be done with this filter
Good that you have use it and was useful to you, I found it on internet.
Apart from the main and original use for what it was made, seeing the presets, I think that this could be used also alternatively as a one image source image jumbler/shatter/breaker if used correctly with selected images, and could give good results
LexArt
LexArt
I am searching for square fonts, images or things that can be used with this filter for feeding the images
For example Grid Fonts where the are some square designs, or modify fonts to be all square, as obviously there is no kerning in FF or in the bomber smile;) smile:D
For example I like this one RodgauHeads font by Manfred Klein
Thanks, glad you like them,
I may think (I would like that I was wrong) that this filter may be underrated and not used much because may be possible that is not understood correctly what is for or how to use it
After thinking differently and considering that this filter opens a really wide and huge door to great potential artworks that could be made thanks to this I think that it can be the best thing to happen for FF 5 and be a revolution in how things may be done
You can create lots of different squares with different content inside with photos, drawings and art made by yourself, or whatever you may think and then be able to make a grid with them and feed it to the bomber and make collage compositions made of those multiple squares.
This filter allows a huge amount of square grids inside one grid so it can make works really very varied and be able to have lots of variations
This filter opens a new door to a huge world of possibilities where only the creativity and imaginagination is the limit
