| jhantares | ||
| Posted: April 1, 2016 3:59 am | ||
| jhantares |
How to use this filter
Component shortcuts SL1-SL6, Kal -> Kaleidoscope components Pxxx -> Pattern components RO -> Rotation component M1 -> Map Script ND -> Noise Distortion component BR -> Bricks component HUE -> Hue component Four different generators alter input image. See following lines on how to use sliders: Set "Select Generator" to 1 Use following sliders to alter pattern: "RO", "SL1", "SL2", "SL3" Set "Select Generator" to 2 Use following sliders to alter pattern: "RO", "SL1", "SL2", "SL3", "SL4" Set "Select Generator" to 3 Use following sliders to alter pattern: "RO", "SL5" Set "Select Pattern" to 4 Use following sliders to alter pattern: "RO", "SL6" Check "Script on" to use "M1" sliders. Check Bricks on" to use "BR" sliders. Check "Noise on" to use "ND" sliders. Check "Kal on" to use "Kal" sliders. Check "Hue on" to use "Hue" slider. |
Nice filter.
A thought : When it is possible, wouldn't it better to add the instructions also in the filter? It is nice that they are here, but it may be more handy if they are in the filter description. |
| Posted: April 1, 2016 6:04 am | ||
| jhantares |
yes, it would be nice, if the instructions could be in the filter.
But in the filter description text format get lost and there isn't enough place. |
| Posted: April 1, 2016 6:40 am | ||
Yes, indeed the description area is limited, so many times it is not possible to write all what we want.
Instead the text format doesn't go lost. If you look at the description here, in the library, yes, all words gets attached. But if you check your FF, and you look at the description of the filter, it is ok. Example : my last filter, Retinatura If you look at the filter page, the the description is messed : Screening made with lines/grids.How to select the grids :Every image is composed of 10 grids. The kind of grid can be choosen with the controls Grid Select. The choices are :1. Vertical2. Horizontal3. Vertical + Horizontal4. Diagonal A (high top on the right)5. Diagonal B (high top on the left)6. Diagonal A + Diagonal B7. Diagonal A + Vertical8. Diagonal A + Horizontal9. Diagonal B + Vertical10. Diagonal B + Horizontal11. Diagonal A + Vertical + Horizontal12. Diagonal B + Vertical + HorizontalWhat else...Oh, did you really find a Chlorophyll control?No, no, I meant ...Color Fill.
But if you check your FF, you will find : Screening made with lines/grids. How to select the grids : Every image is composed of 10 grids. The kind of grid can be choosen with the controls Grid Select. The choices are : 1. Vertical 2. Horizontal 3. Vertical + Horizontal 4. Diagonal A (high top on the right) 5. Diagonal B (high top on the left) 6. Diagonal A + Diagonal B 7. Diagonal A + Vertical 8. Diagonal A + Horizontal 9. Diagonal B + Vertical 10. Diagonal B + Horizontal 11. Diagonal A + Vertical + Horizontal 12. Diagonal B + Vertical + Horizontal What else... Oh, did you really find a Chlorophyll control? No, no, I meant ...Color Fill. |
| Posted: April 1, 2016 6:51 am | ||
