PolyBlooming Design by Ramlyn
http://filterforge.com/filters/13709.html
I had a feeling, so if you made all the lines equal weight when scaled up or down it'll make the output a bit more uniform while variable and interesting. So like those red outlines will be the same thickness per bomber.
I think it'll be a step up. This was just a passing thought I had.
Filters: 712
If I understood well, you mean that, independently from the size of the flowers, the lines should better have the same thickness.
Yes, it is an interesting idea. The small flowers would surely look better.
Ok, I try to see how it comes up. smile;)
Filters: 712
I made a new filter! smile;)
It will not be an update of this but a completely new one. It will also add the textile/fabric look. smile:)
