jhantares
Filters: 272
Psy Pattern Generator 3 by jhantares
http://www.filterforge.com/filters/13690.html
jhantares
Filters: 272
How to use this filter
This filter generates psychedelic patterns using four gradient generator. Select generator by slider "Select Gen (1-4)".
You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR -> Color/Gradient/pattern controls
Kx -> Kaleidoscope components
MO -> Pavement component
Use "GR", "K1", "K2" sliders to generate gradient pattern.
Check "Mosaic on" to use "MO" slider.
Check "Kal on" on to use "K3", "K4" sliders.
ceramix4
jhantares Tnx good filter.
