Filters: 712
Filters: 712
Downloaded! smile;)
Good filter.
You also did a much more complex work than I thought.
The results are very nice.
Oh! This is not the traditional simple sharpen filter, this is much better and expanded version with more option and different possible effects, well done and well thought to be useful and more interesting.
An ultra-sharpening filter using a sparse convolution matrix. Also known as Box Sharpen.
Sharpen Type - 1 - Image, 2 - Saturation, 3 - Brightness.
Sharpen Radius - A value of 1 would be a nornal sharpen. Values between 3 and 20 produce interlocking grid like pattens. Larger values produce a more abstract result.
Shapen Repeat - Determines how many passes of sharpen are used. 1 - one pass, 11 - two pass, 21 - three pass. All other values are fades between these values. NOTE: three pass is slow.
Restore Color - Recovers the colors from "blown out" white areas caused by over shapening.
13 unregistered users.
