Roofing Shingles by Crapadilla
http://www.filterforge.com/filters/1957.html
Here is the first preset in high-detail for comparison.
purty cool there, crapadilla.
John Michaud
Student
Filters: 7
I really like what the direction your taking this filter, your managing to capture slate tiles pretty damn well.
That being said, my question is are you intending to make them look so thick? Because as it is if you were to think of this in 3D space, those tiles look to be about 1 1/2 to 2 inches thick.
I intended to make them rather thick, yes, but you have a point. Maybe I should make that thickness tweakable.
As (almost) always, this is a work in progress, and I am open to suggestions. Originally, I also intended to implement a random vertical shift for the shingles as well, but that would require drastic rewiring/rebuilding. Currently, I am experimenting with making this thing render faster. With global detail turned down to zero, its still pretty much a slug. smile;)
Also, there is a strange repetition of detail happening on every second tile row when rendered for seamless tiling (as seen on all preset renders). The next update will introduce a remedy for this.
Updated. You can now tweak the slate thickness. smile:)
Beautiful. The only thing I'd like to see is more natural-colored presets -- blue IMO isn't a 'roofy' color smile:) Maybe the default look can be changed to look more natural -- like the second preset but with less crackles.
Vladimir Golovin wrote:
blue IMO isn't a 'roofy' color Smile
My reference for this filter... smile;)
Since these are more like slates than clay shingles, I thought I might get away with it... smile:D
smile:D That's fine -- I suppose the dominant color may vary from country to country.
Then again... maybe I just switch around the colors of the first and second presets in the next update.
The next update will focus on 'Advanced Pattern Repetition Cloaking' technology. For some of the presets with low 'Repeat' values, the crack pattern repeats were just too painful! smile;)
Another example.
And this is what it looks like with the special Crapadilla cloaking device turned on...
picky, picky, picky smile;) looks pretty damn good to me.
oh, and on the slate one, slate is that color but not that texture, generally. slate tends to be a layered type stone, not solid like you have it. it's somewhat like shale in that it splits very easily into sheets, which is why it was used as roofing at times. you can split slate into fairly thin pieces, but it only splits this way in one direction. think of vinyl tiles stacked one on top of another and then pressed together. the bond within each tile is stronger than the bond between each tile. so, you end up with a layered look.
so, the first example in this post looks more like a granite than a slate. slate wouldnt be that thick for roofing or siding. but the color does seem right.
Zephos
Xyni says "Maximum w00tness!"
Filters: 31
I don't know much about roofing or shingles, but it certainly looks incredibly lifelike to me! ^_- Excellent work Crapadilla and the fact that you are working to make it even better is nothing short of inspiring!
Kraellin, you certainly know your building materials ^_^ I would have never noticed all that about how slate and the other materials are unique until I read your write up ^_-
-Zephos
zephos,
well, i hope i got it right. it's been a while since i've bought and used stone smile:)
Torley
Second Lifer
Sweet. Crapadilla, I like the work you put into giving them a grain and worn feel. On the more aged-looking ones, I almost wonder if I might slip on a shingle (missing shingle slider? Haha) and fall off the roof. smile:)
Seriously, I was looking at some texture packs that architects use, and they were DRY AND BORING. Something like this could breathe more life into the staid, plain vector art currently (and unfortunately) out there.
I'm enjoying using Filter Forge to create http://torley.com/textures
Nice idea. I will look into this for future versions...
Dilla, those are really cool!!! Wouldn't it be sweet if FF had a 3D environment to do things like this smile;) smile:)
Wouldn't it be sweet if FF had a 3D environment to do things like this Wink Smile
No, that's what dedicated 3D applications are much better at... smile;) smile:D
I'd rather FF remained in its own area of expertise!
Yeah, Vlad said the same thing to me when I've mentioned it before smile;) smile:D
I was thinking big.....retaining everything as sub-environments within FF.....using PS, PSP, etc as editor plugins to FF......and doing the same with 3D, animators, etc.....basically having the ability to put the whole "shopping mall" customized right inside of FF.....making it the center of the graphics universe smile:devil:
Okay, first we'll need unlimitted financial resources and an army of programmers..... smile;) smile:D
Yeah, Vlad said the same thing to me when I've mentioned it before Wink Big grin
That's because I always make sure my sock-puppet accounts don't know eachother in order to keep it surreal. smile;) smile:dgrin:
oh that's just cool, dilla smile:)
ya know, i tend to agree about keeping FF as FF, but i was thinking recently, since i've been playing with gtkradiant here lately, that 'shaders' might have a really good use in FF. shaders are basically scripts added to an image, object, or texture to give it more parameters and be less static. like, you could have a picture of a starfield, but you could add a shader to make the stars twinkle. that could be very cool!
LOL.... so that means you own FF.....the Mac version was just a clever ruse.....and version 2 will be released next week!!! smile:beer: smile:beer: smile:beer: LOL....
Update incoming.
This will address some texture discontinuity and height map issues that I inadvertently introduced in the last update. [Gah! Fixing things until they're broken smile:evil: ] See them for the last time below...
ahimsa
Filters: 41
Looking forward to it. This is one of the first filters I downloaded. smile:)
Begone, bad fixes! smile:D
La Shonda
love this one..thanks for sharing... smile:)
91 unregistered users.
