DJI
Official Bologna Tester
Filters: 257
Foreign Planet by ZZ_NT
http://www.filterforge.com/filters/13630.html
DJI
Filters: 257
Hey! Great stuff. A few stars in there would be good to.
ZZ_NT
ZZ_NT
Filters: 11
Thank you! smile:) Stars can be controlled (a bit) smile:D
Cliff3D
Cliff3D
Using the latest FF15 I can't even preview this filter (Library_13630-1.ffxml) it brings my i9 CPU usage up to 100% and - after hours - causes my laptop to reboot.
Can anyone else confirm or provide an answer to this?
Cheers,
Cliff3D
Clearly I may be wrong and the reason could be something else entirely.
Filters: 712
I confirm that it is very slow.
I think that the problem may be caused by the number of iterations of the Loop component.
You can try this:
1) Click on the filter but don't stay waiting for the rendering, open it with the editor.
2) Click on the Loop component and change the number of iterations to a smaller value, for example 5.
3) Save the filter with a new name.
The result will not be nice as the original, but still similar.
Anyway...... I don't remember that this filter was so slow before.
I wonder if some change in a recent version of FF made the Loop or some other component work slower than the first versions of FF.
Cliff3D
Cliff3D
Many thanks for such a rapid response!
I am sadly something of an innocent when it comes to editing filters in Filter Forge... So... let me see...
1) Clicked on "Foreign Planet" filter.
2) Selected "Filer...Edit..."
3) Tweaked zoom and pan to show the area where there is a loop
4) Bain melted. I can't see how to change any values relating to the loop... indeed, I can't see any values relating to the loop. However, by bypassing the Loop between PerlinNoise 13.005 and Blend 6.003 I get a result. Now I'll just have to learn a bit more about how these nodes work!
5) OK, the term "Loop" features a lot in the "Library_13630-1.ffxml" file as edited with a text editor, so there's something I can look at if I hit a brick wall with editing the Filter within Filter Forge smile:)
Cheers,
Cliff3D
Cliff3D
Cliff3D
I've cheated very slightly and edited a saved copy of the filter in a text editor, where I have changed the "Iterations" of the loop from 13 to 6 (as below). It is taking quite a while to execute, but I *MIGHT* try 7 if I'm feeling brave.
Code
      <Loop id="loop 01">
         <Accumulator source="perlinnoise2 01"/>
         <Iterations value="6"/>
      </Loop>
My apologies for nerdily resorting to a text editor rather than taking the time to figure out how to edit the filter properly smile:(
PS LOL - OK, so if I click on a node it's properties show up in a box to the left of the screen and I don't have to grab a text editor. Got it!
Cheers,
Cliff3D
Code
      <Loop id="loop 01">
      </Loop>
Cheers,
Cliff3D
You beat me to answering your own question. I was gonna suggest editing the xml. It always helps in a bind but not always. Loops are great but
it depends on what is in that loop and how many iterations are used and if they are nested...
Cliff3D
Cliff3D
I've found that knowledgeable people prefer it if "innocents" at least TRY a little. I'm told that I am VERY trying, so I think I must be getting it about right.
It would appear that whatever aspect of Filter Forge is making this filter slow isn't new, as it's been slow for years. I wonder if Filter Forge would be interested in finding out what change caused this issue.
I reckon, from partial renders, that 7 is probably the minimum number of iterations through that loop. Which takes itself a goodly time to render but I am hoping to be able to produce a set of preset thumbnails.
Cheers,
Cliff3D
Taken out the curve component from the loop does speed it up......
Then taken the part of the filter that creates that land outline and create it outside of the loop makes it quicker. Needs some more tweaking to get the right look...
Cliff3D
Cliff3D
How odd! I quoted someone earlier without difficulty. Hrm.
CFandM Then taken the part of the filter that creates that land outline and create it outside of the loop makes it quicker. Needs some more tweaking to get the right look...
Looking promising! I must admit that you've left me completely behind though. The most I've been able to achieve with the filter editor is to rearrange the nodes so that the connections are more obvious to me. Still, I've been tinkering and tinkering... I even wondered about duplicating large pieces of the workload rather than have them in a loop, but for that I would have to better understand how the "accumulated" aspects work (don't try to explain it to me - I am being far too slow of brain at present. I'm going to blame the heat this time, I think).
Cheers,
Cliff3D
Cliff3D
Cliff3D
The main thing I've done and not then deleted is reordering the nodes in the filter so that it seems a bit "cleaner" to me - no connecting lines passing behind nodes and as few crossing lines as I could manage.
From there I have repeatedly tried - and failed - to reduce the filter to the minimum possible and yet still exhibit the speed issue.
Cheers,
Cliff3D
Cliff3D
Cliff3D
So first I usually remove the "Blend" node and then the "Perlin Noise" and associated "Continents" colour node.
Then the "Oceans" colour node, the "Profile Gradient" and the "Refraction" node.
I hope to be able to reach a stage where it renders as little as possible, demonstrating that the problem is the loop, or the "Accumulated" aspect of the loops, or the Ellipse or whatever. I've attempted this a few times and got stuck, but I might have another quick play now.
Cheers,
Cliff3D
Cliff3D
Cliff3D
I've managed to simplify the filter down to this - not to produce the desired result but to illustrate the problem. Run this filter in FF5 and Bob's your uncle. Run it in FF6 and it practically stalls smile:(
Cheers,
Cliff3D
Cliff3D
Cliff3D
Here's the actual filter file!
FilterForge support have been quite polite about this issue, so I'm either being helpful (as intended) or am coming across as a barmpot and best humoured from a safe distance.
Foreign Planet - examining 003.ffxml
Cheers,
Cliff3D
Cliff3D
Cliff3D
I made a boo-bo in that I left the Ellipse connecting to the wrong node on the Wave component. It should be corrected in the filter file.
Interestingly, if we take the Ellipse out of the filter as per this image, it doesn't suddenly render super fast like FF5 does, but the CPU usage does drop to 44% instead of 100% if rendered with the Ellipse attached.
Cheers,
Cliff3D
