jhantares
Filters: 272
KalPat Generator 5 by jhantares
http://www.filterforge.com/filters/13538.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 4 different generators. You can alter the patterns by using assigned sliders. See following lines on how to alter these patterns.
Component shortcuts
GRxxx -> Gradient/Pattern control
K1 -> Kaleidoscope component
Set "Select Generator" to 1
Use following sliders to alter pattern: "G1", "G12", "G123"
Set "Select Generator" to 2
Use following sliders to alter pattern: "G2", "G12", "G123", "G23"
Set "Select Generator" to 3
Use following sliders to alter pattern: "G3", "G123", "G23", "G34"
Set "Select Generator" to 4
Use following sliders to alter pattern: "G4", "G34"
Check "K1 on" to use kaleidoscope component altered by sliders "K1".
13 unregistered users.
