jhantares
Filters: 272
NIK Generator 23 by jhantares
http://www.filterforge.com/filters/13522.html
jhantares
Filters: 272
How to use this filter
Generates interesting kaleidoscopes by using the source image or two different gradient generators. There are different masks used to generate a new kind of kaleidoscopic patterns. See following lines on how to use sliders.
Component shortcuts
Gnnn, GK -> Gradient components
K1,K2 -> Kaleidoscope component
Set "Select Generator" to 1,2,3
Use sliders to alter gradient pattern: "G1234","G12345"
Set "Select Generator" to 4
Use sliders to alter gradient pattern: "G1234","G12345", "G4"
Set "Select Generator" to 5
Use sliders to alter gradient pattern: "G12345", "G5"
Check "Gradient Kal on" to use "GK" sliders.
Check "Kal1 on" to use "K1" slider.
All generators are altered by sliders "K2".
12 unregistered users.
