fractalartist1
fractalartist1
Marble Colors by Martin Naumann
http://www.filterforge.com/filters/13387.html
Bored? Come check out my digi-artist resource store at:
http://www.renderosity.com/mod/bcs/in...dor=197501
fractalartist1
fractalartist1
Why not seamless?
Why not seamless?
Remove the "scale" transformation at the end of the tree and enable seamless tiling via "overrides" menu.
Looks like the filter needs work. The input from noise gradient --> gamma --> brightness/contrast is unnecessary, in fact may be slowing the filter down significantly. Much of the "noise gradient" should be enough to produce the gradient necessary for the final look. If by any chance noise-gradient doesn't cut it, it's better using a profile gradient with a noise curve. That should give enough control to allow gamma and brightness/contrast to be bypassed completely.
[Edit] A screenshot should clarify what I'm trying to say above.
12 unregistered users.
