| Posted: January 29, 2007 2:25 am | ||||
Yes!!!! you did it!
| Posted: January 29, 2007 2:27 am | ||||
The only thing missing is for it to automagically understand which aspect your image is. That way a manual switch wouldn't be nessessary. |
| Posted: January 29, 2007 2:35 am | ||||
I don't quite get that last bit about the automatic understanding of aspect ratio but I haven't had time yet to fool around with this one (all work and no play). I'll try and implement it into this filter tonight (it badly need this snippet). Maybe I'll get it then
| Posted: January 29, 2007 5:28 am | ||||
sjeiti,
and image can have 3 basic aspect ratios, length longer than width, width longer than length and width and length the same. his proportional gradient works fine with one of those, but you have to rotate it to make it work right with the others. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: January 29, 2007 3:50 pm | ||||
Horizontal images require one part of the snippet and vertical images the other part. That's why there's a checkbox titled "H Mode"... Checked = Horizontal Image Unchecked = Vertical Image *Both modes work for square images |
| Posted: January 29, 2007 4:23 pm | ||||
ah, ok. i knew it was something like that
| Posted: January 29, 2007 9:03 pm | ||||
Sadly it doesn't work when you set 'Size, pixels' to anything other than the maximum value...
![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: April 19, 2007 10:26 am | ||||
That's why I think a "Fixed Size" option on all components tied to the "Size, Pixels" control would be a good idea..... This filter should not be a "Low Usage" rank.....which is why I think FF should do away with "Low" and have "Average" as the lowest rank....and have the ranking like this.... 1) Average 2) Above Average 3) High 4) 2x High.....3x High.....etc.... The "Low" ranking brings an unnecessary and misleading negetive connotation with it that says that the filter is bad.....which is certainly not the case with this filter..... I think FF could find a way to deal with 'sub-optimals' under the lowest rank being "Average" so the actual good ones don't get penalized with the 'sub-optimals".....maybe by sending an email to authors stating that their filter is scheduled for deletion if it is not drastically improved.....or something like that..... Uber, great filter!!! Very clever how you worked this out!!! Steve
| Posted: September 12, 2007 12:26 pm | ||||
it's really an amazing piece of work.
but it is a 'low usage' filter. but, like you say, that doesnt make a 'low value' filter. when you need it, there really is no other substitute for the thing. but it also comes with a price. that thing does slow filters down. and we're all anticipating version two of FF to break the non-square issue... i hope. but, if you notice, even though it's low rank, the FF team havent pulled it and relagated it to 'my filters' like they have with some other low usage filters. so, i dont think that's an automated process and so i'm fairly sure it's not going to be culled from the library. i know what you want, steve. you want a way of designating that even though it's low usage it's not low in value and i tend to agree, but going all politically correct on calling low usage, average, still doesnt seem the right way to do it to me. if you wanted to add an extra category in there that said something like 'invaluable' or 'specials' and still keep the low usage marks, that would work. and i think snippets are also treated a bit differently by the FF team when they go to cull low usage filters. and perhaps they are, if the thing is automated, left out of that process. dont know about that. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: September 12, 2007 12:38 pm | ||||
Yeah, to users like you and I, we can "see thru" the 'Low' ranking and distinguish between 'sub-optimals' and that ranking being due to snippet integration.....but general users might not see it that way and just think it's a bad filter.....
I don't think FF has deleted any filters because of a 'Low' usage rank, but I could be mistaken. FF told me that filters are not deleted from their data base when an author asks for them to be deleted....they are just "hidden"..... Steve
| Posted: September 12, 2007 12:49 pm | ||||
steve, i get messages every once in a while that filters have been culled and 'moved to my filters'. i get that message at various times when i download new ones. so, it does happen. however, i dont recall the message giving a reason why.
| Posted: September 12, 2007 12:51 pm | ||||
Really??? You have had filters deleted by FF???
| Posted: September 12, 2007 12:55 pm | ||||
they dont get deleted. they get moved to 'my filters' automatically. any time you get one of those messages about the library being re-structured, read the whole message. it's sometimes in that type of message.
| Posted: September 12, 2007 1:16 pm | ||||
They don't get deleted, but only get moved to "my filters"??? I've received the "some filters have been moved.....re-structured" message.....but haven't figured out what they have done beyond just moving some filters around.....
| Posted: September 12, 2007 1:29 pm | ||||
yeah, i got one recently. 'some filters have been moved to my filters'. or something close to that.
| Posted: September 12, 2007 2:39 pm | ||||
Foxxee
Perfect idea, would eliminate the need to always remind people before using your filter to do so for 'best results' ~Foxxee~
You are more than welcome to use and learn from my FF filters ;) |
| Posted: September 12, 2007 8:06 pm | ||||
| Nic74 |
Thanks for this one, I nearly gave up on my filter after testing all gradients trying to cheat filter forge. (your solution is brilliant
| Posted: October 4, 2007 3:14 am | ||||
50 unregistered users.
