Acid Sky by Martin Naumann
http://filterforge.com/filters/13464.html
Hey there! You got nice colors going.
I got a suggestion for you, you should combine the bulk of those filters you just uploaded to 1 or 2 filters. Acid Sky filters may be functionally different but the coloring, style is very much similar.
There are benefits to doing that:
+ instead of downloading 3 filters, you just have 1 filter to do all the creative explorations on. This is friendly for the user as well, settings can be stored and saved on just 1 filter, not across 3 filters that look the same.
+ It's probably better just to have 1 than tons of the similar thing. It's better house keeping, and it also helps reduce the number of search results so you can narrow in on the thing you really want.
+ It's easier to update 1 filter than 3 or 4 or 5 or whatever.
Point is, combine those filters. And while it is your choice to do that, there's just a ton of benefits for doing that anyway. But either way, this is just a passing suggestion.
Like it, very colorful and nice patterns that really look like acid spilled on a reactive surface
Martin Naumann
Martin Naumann
Filters: 98
thank you both! smile;) but i don't know 100% of all functions FF have so sometimes i don't know how to put them all in one
No worries, I usually look at some people's filters and I sometimes don't know myself. I think I can help you out here. Although what's submitted is what's submitted so no point doing that here. I guess that suggestion would be for next time.
The key to FilterForge is that you can diverge the stream of data almost anyway you want. For example, if you see some similar node structure being used across any of your filters, then you have a chance at merging them into 1 filter. At the simplest level, given how FF lets you split streams, if you see the same node being used across 3 filters, you can always just use 1 of those nodes to affect everything downstream from there.
33,833 Registered Users
+9 new last day!
15,390 Topics
16 unregistered users.
