DJI
Official Bologna Tester
Filters: 257
Postage stamp by Kochubey
http://www.filterforge.com/filters/13438.html
Erik Pedersen
Goggerfett
THANK YOU! THANK YOU! THANK YOU!!!!
Thanks also for making it 'smart' so that it works even if your image isn't perfectly square. AWESOME!
The Joy is in The Work
DJI
Filters: 257
Really great filter. I love it. smile:D Check it out. Here's the original. smile:)
DJI
Filters: 257
Result#1. smile:D
DJI
Filters: 257
Result #2. smile:D
DJI
Filters: 257
Result #3. smile:D
This gives a very good frame effect and great result of a postage stamp, but fr om seeing the examples, it seems that it CUTS the source image, and I know that is possible to make a filter frame wh ere the image is resized dynamically so the source image is not being cut, I do not know wich filter is, but it can be done and works well, is a pity that such a great and nice postage stamp frame cuts the source image
There is an alternative to the image cut, I mean a way to avoid it, and is to include in the source an additional white frame around the source image with the same size of what the filter will be cutting, so then the source will look full
brgljez
mrrr.grrrr.brrrr
Filters: 4
great
lbs
Hello Everyone, I am new to this software but purchased the professional version so that I could use the Postage Stamp filter. I am having trouble with getting the perforation to be the same on all 4 sides. Please see attached. The bottom edge is different than the other 3 sides.
Thanks for any help.
Lbsutton
