Filters: 712
Filters: 712
Nice and very intuitive. smile:)
If you feel to add something and do an update, I would suggest the chance to invert the swirl (you can easily do it adding a Flip component + a Checkbox control ).
I'm curious about your forum name : JubJub.
In Thai "jub jub" ( other times written "chup chup" or "jup jup" ) means "kiss kiss".
But maybe your forum name is not from Thai. smile;)
JubJub
Filters: 3
Have just uploaded an update for some errors. Will add your request to next update smile:)
JubJub is just my online name I have used for many years. Thank you for telling me it's meaning in Thai smile8)
Filters: 712
Downloaded. smile;)
DJI
Official Bologna Tester
Filters: 257
Very cool man. smile:D
PayPaul
PayPaul
I don't know if this is a bug in the filter or my version of Filter Forge (7.007) but when I choose alpha or transparent as the background, that background appears in the preview as black.
Don't step on a dead dogma. It'll turn up again and bite you!
PayPaul
PayPaul
The image as saved:
JubJub
Filters: 3
@PayPaul, it's my bad - I will fix for next update/filter cycle.
PayPaul
PayPaul
I'm sure you can fix it. Thanks. I like what I created with it. I want to make some Photoshop brushes with it. Hence the need for the Alpha transparency.
PayPaul
PayPaul
I've done some editing on my own of this filter. I've noticed some other strange behavior that perhaps has to do with my editing. It appears when I change the background colors. Perhaps my addition of HDR to the color components has changed the way shapes are made. I'll try attach the FXML of my edit.
JJ_ StarMaker XY Anchor edit.ffxml
JubJub
Filters: 3
@PayPaul , here is fixed foreground/background version.
JJ_ StarMaker.ffxml
PayPaul
PayPaul
I see you fixed it by adding a blend component between the result and the rotate component. After that you reconnected the color and background color components to the blend component. Looking at the change was a learning experience for me and so I applied the same fix to my edit of your filter.
