Haras Arch
Hara's Crown
Looping NIK Generator 19 by jhantares
http://www.filterforge.com/filters/13369.html
Haras Arch
Hara's Crown
Very interesting! Like the metallic.
jhantares
Filters: 272
How to use this filter
Component shortcuts
RO1,RO2 -> Rotate component
FR -> Free Rectangle component
K1-K4 -> Kaleidoscope component
Iterations 1 -> set how often pattern transformation is repeated
Flip X, Flip Y -> Flip component
HSL -> Hue,Saturation,Lightness component
Image passes "K4" kaleidoscope, rotate this image by sliders "RO1-". A "Free Rectangle" component cut a slice out of the image, use sliders "FR" to alter slice form.
Slider "Iterations 1" alter slice repeating, slider "RO2-" alter rotation of repeated slices. Check "Flip on" to use "Flip X and/or Flip Y" checkboxes, check "K2 on" to use kaleidoscope "K2" and check "K3 on" to use kaleidoscope "K3".
Check "Kaleidoscope on" to use kaleidoscope "K1" right in front of "result" component. Kaleidoscope "K1" can be altered by sliders "K1". Check "Show Slice" to see slice cut out. Check "HSL on" to use "HSL" sliders.
You get interesting new patterns by using the looping components.
20 unregistered users.
