Haras Arch
Hara's Crown
Kaleidoscopic Slices 18 by jhantares
http://www.filterforge.com/filters/13370.html
Haras Arch
Hara's Crown
Wow! Really nice.
i think that if you are making different versions, maybe it could help to explain what is different from other kaleidoscope filters or versions of your well done collection
So if it may be explained a little what his filter has in difference to others, and avoid thinking that "this is another same kaleidoscope filter" and so give a reason why you should download it
By the way reading the description INSIDE the filter is not allowed for the FF user that has the basic FF Version
I would like to download your beautiful and well done collection of kaleidoscope filters, but do not know why they are different between each other, what makes them different and choose one vs another.
Thanks
jhantares often leaves instructions for each filter which kinda sheds some light on what's different.
You know, as an author, I still STILL encourage lumping these filters together in some fashion rather than making more version counts. If they follow similar design principles, they should be formed into 1 filter, that's as loose of a rule it can be. Not saying you should combine all of them, just saying something reasonable for both you and the rest of the users.
There are many benefits if you lump filters together and I'm pretty sure you'll find something new in doing so.
I know you had some reason for doing that, but again, from an end user perspective, I'm dropping off a thought. It's a cool design, I just wish you'd figure a neat way to put your work together into 1 neat filter. If you need help I'd gladly do my best to figure something out for you. But again, up to you! smile;)
jhantares
Filters: 272
How to use this filter
Component shortcuts
PA -> Pavement component
K1,K2,K3 -> Kaleidoscope component
M1 -> Script component
RO1 -> Rotation component
TI -> Tiles component
FP -> Free Polygon compoent
Four different generators alter input image. See following lines on how to use sliders:
Set "Pattern Selector 2" to 1
Use following sliders to alter pattern: "K1", "TI", "RO1", "K2"
Set "Pattern Selector 2" to 2
Use following sliders to alter pattern: "K1", "K2"
Set "Pattern Selector 2" to 3 and "Pattern Selector 1" to 1
Use following sliders to alter pattern: "K1", "TI", "RO1", "M1", "K3"
Set "Pattern Selector 2" to 4 and "Input Selector 1" to 1
Use following sliders to alter pattern: "K1", "TI", "RO1", "M1", "K3", "FP"
Set "Pattern Selector 2" to 4 and "Input Selector 1" to 2
Use following sliders to alter pattern: "K1", "K2", "FP"
18 unregistered users.
