Haras Arch
Hara's Crown
Artistic : MultiCenter by Ramlyn
http://www.filterforge.com/filters/13359.html
Haras Arch
Hara's Crown
Nice effect! Although the preview seems a bit slow to load (I haven't tried to save any images from it).
Filters: 712
Thank you!
I'm working on a new type, using a different solution to obtain a similar effect. It may be faster. smile;)
DJI
Official Bologna Tester
Filters: 257
Hey! I like this one just the way it is! smile:D smile;) The way the rectangle spins around and layers together to make all those ragged edges is really great. I noticed that in the depth map group you used the old offset component. I know just what you mean. That one is a lot more straightforward to use.( at least for me ) smile:) As far as the design of the group result,I'm not quite sure what it's doing for the overall image. smile:?: Check it out. Here's the original.
DJI
Filters: 257
And here's the result. It was rendered and saved @ 2732x1536 rez in about 4 min. Nice! smile:D smile:D
Filters: 712
Thanks DJI!!
The group does two different things :
It is connected to Rotation to set the disposal of the particles. Design Rotation is used to rotate the particles in different directions. Design Repeat is used to increase or reduce the number of centers for the particles rotation.
It is also connected to Depth Map to give someway a checker-like effect ( because of the repetition of dark and clear areas of the gradient ).
DJI
Filters: 257
I see. Yes,I was wondering about the dark and blurry areas. So the dark squares go down and the blurry areas go up. Interesting. Thanx for the reply. smile:D
Like it, very good, is creative and well done, beautiful and curious effect
Filters: 712
Thanks SpaceRay. smile:) smile:) smile:)
The new Artistic : Multicenter G is similar, but with some changes.
20 unregistered users.
