Haras Arch
Hara's Crown
Wallpaper Group 2 p2 by Rick Duim
http://www.filterforge.com/filters/13362.html
Haras Arch
Hara's Crown
Here's one I made using this filter:
Haras Arch
Hara's Crown
Am I seeing correctly that there are 5 different possible shapes for the seed tile: parallelogram, triangle (upside down or right side up), and two different sizes or rectangles? (There are 10 options on the selector, but I think I only 5 are different.)
The Tile Type has 5 different "seed" shapes. The only thing with 10 options is # of Tiles, which just adds more rows & columns of the same thing (but smaller tiles, of course).
Did you read the About description of how to use the filter?
Haras Arch
Hara's Crown
Now I have smile8)
Actually, it lets me type in up to the number 9 for the seed shapes -- but the higher numbers don't produce different results.
All of the controls are like that. If you type in 200 for a control that only goes up to a 100, it reverts back to 100. Once you click out of the field, it corrects the value. You might want to use the slider controls for a bit to get used to the idea of limits smile:bunny:
Haras Arch
Hara's Crown
Yeah, I tend to jump right into things and try to figure out how they work without reading all the instructions first. Kind of a sink or swim approach smile:)
And, to be truthful, I do the same with most filters. In this case you have live filter support smile8)
21 unregistered users.
