Tips:
1. If you go "full quality" due to a couple bitmap components it'll run relatively slow. Make sure you preview your stuff before you start rendering!
I added a "preview lines" check box to help you design things the way you want before applying the rest of the fancy stuff on top. Alternatively, you can export just the preview lines and apply the glow effects yourself which will also save a lot of time.
2. Fast blur checkbox disables Gaussian blur for the glow effect. This effectively makes the filter run extremely fast so it might be to your advantage. Note that by doing so you sacrifice the fine, awesome quality of gaussian blur so make sure you preview stuff before making your final choice.
3. If you're wanting a bit less jitter in the lines, increase anti-alias sample counts.
4. This filter was produced partially to process video. I thought it was cool, but it was too slow so I found a different method to do the same thing in After Effects. But it's a fun little thing so give it a shot. Also 5.0!! smile:D
Here you go. This looks like my go to Glowing Edges type filter from now on smile:D Here is a 12 color Julia set through the Glow Wires.
DJI
Official Bologna Tester
Filters: 257
Hey! Great stuff Skybase. smile:D I can't wait to get my upgrade to try it out. smile:D
WOW!! This looks very good and well done, like much the glow effect that this can give shown on the presets, I will have to test it to see how it works
Thanks DJI for the nice example
Also 5.0!! smile:D
Congratulations of being the first 5.0 filter, I did not know that it was already open the FF 5.0 filter submission
Well the first was https://filterforge.com/filters/13355.html
Although technically I think this would be the first in queue to be the first user-submitted Filter from FF 5.0.
Martin Naumann
Martin Naumann
Filters: 98
wow this one is really cool! smile:) love the idea
11 unregistered users.
