jhantares
Filters: 272
MosPat Generator 23 by jhantares
http://www.filterforge.com/filters/13350.html
jhantares
Filters: 272
How to use this filter
This filter generates patterns using 3 different pattern sources. You can alter gradient and pattern by using assigned sliders. See following lines on how to use sliders.
Component shortcuts
GR,GR1,GR2,WA,RO3 -> Color/Gradient controls
RO1 -> Rotate component
NO -> Noise Distortion component
TI -> Tiles component
K1,K2,K3 -> Kaleidoscope component
PA -> Pavement component
OF -> Offset component
BC -> Brightness/Contrast component
Set "Gradient Selector" to 1
Use sliders: "GR1", "RO3", "GR2", "WA"
Set "Gradient Selector" to 2
Use sliders: "GR2", "GR", "RO3", "WA"
Set "Gradient Selector" to 3
Use sliders: "GR Frequency", "GR Invert", "GR1", "RO3"
All gradients are altered by sliders "OF", "NO", "RO1" and "K3".
Set "Pattern Selector" to 1
Use generated pattern as is.
Set "Pattern Selector" to 2
Use sliders: "TI"
Set "Pattern Selector" to 3
Use sliders: "TI", "PA"
Set "Pattern Selector" to 4
Use sliders: "TI", "PA", "K1"
Check "Kal2 on" to use "K2" sliders.
Check "BC on" to use "BC" sliders.
