jhantares
Filters: 272
NIK Generator 21 by jhantares
http://www.filterforge.com/filters/13347.html
jhantares
Filters: 272
How to use this filter
Generates interesting kaleidoscopes by using the source image or two different gradient generators. There are different masks used to generate a new kind of kaleidoscopic patterns.
See following lines on how to use sliders.
Component shortcuts
GRx -> Gradient components
RO3 -> Rotate component
BR -> Bricks components
ND2 -> Noise Distortion component
K1,K2 -> Kaleidoscope component
HSL -> Hue,Saturation,Lightness component
Set "Image/Grad. Selector" to 1
Use "Source image"
Set "Image/Grad. Selector" to 2
Use sliders to alter gradient pattern: "GR2", "GR23"
Set "Image/Grad. Selector" to 3
Use sliders to alter gradient pattern: "GR3"
Uncheck "GR3-Selector" to use "GR23-Color 1" slider. Check "GR3-Selector" to use all "GR23" sliders.
Use "Pattern Selector" to choose a predefined mask.
Check "Bricks on" to use "BR" sliders.
Check "Distortion on" to use "ND2" sliders.
Check "K1 on" to use "K1" slider.
Check "K2 on" to use "K2" sliders.
Check "HSL on" to use "HSL" sliders.
Haras Arch
Hara's Crown
Interesting! I like your NIK Generator and Kaleidoscopic Slices series. Thank you for creating them!
jhantares
Filters: 272
Thanks for your kind comment. You can expect some more of these filters in the next weeks/months. I have some more of this kind, perhaps you like them also. smile:)
Haras Arch
Hara's Crown
Good! I think I've downloaded all the "effects" NIK and Kaleidoscopic Slice versions (I use them more than the textures).
Thank you for all your hard work. I'll enjoy seeing the new ones as they come out!
