I wonder why there are some filters that the presets shown on the FF Library website are NOT the same as the ones available on the filter presets?
IF you activate the seamless tiling THEN the preset is the same as the one shown on the FF Library I have seen some filters where in the FF library you can see some presets and then after you download it and when inside FF, the presets are different or very different (depends on the filter) and as said it is solved when activated the seamless tiling Why happens this? Why the preset does not keep the seamless tiling activated? Why is shown a preset with seamless tiling in FF Library and then it is not included in the preset downloaded? EXAMPLE FILTER Although there are some filters, one I have seen that happens this is Bone Struct by Adrian G If anyone knows would be good to know Thanks |
| Posted: October 27, 2015 5:34 pm | ||
Its actually quite simple....That is a version1 filter....During this time you submit the filter and the presets are rendered on FFs end and not on the users end....When these were rendered on FFs end they were automatically rendered as seamless tiles even if the filter was not designed for seamless tiles....If you submitted a filter with the seamless tile unchecked the odds are good that the presets would look different on the filters webpage.....
So when you download the filter the preset will look different and be as the filter author intended....... Since FF is now rendering the presets on the filter authors computer before submission of the filter the presets displayed on the filters webpage is now a different scenario........... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 27, 2015 8:24 pm | ||
Oh, I understand this happen only to FF 1.0 filters as it was done differently
Thanks very much for your detailed and well done answer, undestood it perfectly the reason, now I know why |
| Posted: October 28, 2015 3:27 pm | ||
