Stobberly
I am using the Sketchy Painting filter and am using it on an image that has a transparent background. I am trying to get the filter to ignore this background completely and even maintain the alpha channel so that I can import it back into photoshop and still be able to easily select the object and ignore the transparent background. Is there an easy way to accomplish this? Thank you!
Stobberly
I fixed my problem. I used "Blend" and the "Get Alpha" nodes and just blended the inverted alpha mask to my final image and everything worked fine. But one other problem was my PNG for some reason wasn't originally importing the alpha channele, which I resolved by re-creating it in photoshop.
