DJI
Official Bologna Tester
Filters: 257
GF Landscape Gen version Canyon by Ghislaine
http://www.filterforge.com/filters/13310.html
DJI
Filters: 257
Nice! smile:D It's a little blurry for my taste. It seems to me that a lot of filter makers around here have an aversion to mapping the sharpen component into the result. smile:?: smile;)
I had to blur just a bit (only 0,5) because of the vertical lines at the top when the deepness is on, without this little blur, canyons do not look so good or not enough representative. smile:)
And an example using the altered filter.
UPDATE: Also applied this change to your Rocky Mountain filter. Try it out.
Ramlyn (because his name appears as the author of the filter into the general info) and you Rick (because you have altered my filter), you misrepresented my filter. The worst is that you allowed yourself without consulting me, for putting your version on the forum where it is acceccible to all even to non members of FF.
You have done wrong because it would have been better and abiding email me to tell me first and send me your test filter. I feel that my work has been flouted and that I have not been respected. There is not a snippet but a filter on which I worked hard which should be only in the library.
I took the same three images of your upgrade my filter and my filter. I confess to being upset and shocked. Your update does not suit me, it distorts my filter. There are more blurring in your update and shadows are distorted. Also, the curves of the canyon are curved inside and not outside as I created them. Watch these differences in the following images.
Also, by doing so, you prevent my work to earn a reward. I ask GMM or direction to remove the update that you put on my thread and that should never have been there. I was happy to share with you my work. But if it's like that, I will not share my filters anymore, I'll keep them to myself. This is unacceptable, I never acted like that. Again, this process is unacceptable. We do not do things like that . I am disgusted.
First image from your update
second image from my filter
with my filter, same image
other example, with your update
it is more brurry
with my filter, less blurry
with your update more blurry
with my filter, more clear
If you cannot see a difference, you must wear glasses. smile:evil:
I has about 7 more landscapes that you will not have to change anything because you will not see these filters in the Library.
Also note that an update of my filter is my business, not yours.
Just an idea. Pardon my idea. It was not intended to be released, just showing you an idea. My apologies. Ramlyn's name on the filter is a mystery. I just edited it and posted it not realizing the name had been changed. I will never touch one of your filters again. In fact, I am leaving the forums for awhile. My intent was not to disgust you, however I am now disgusted with the whole thing.
UPDATE: GMM, Please remove my test filter posted above. I did not intend to offend, but I have. Wrong author on the filter... I'd like to know how the software did that when I did not edit the author name.
Djekki
Filter Forge, Inc.
Filters: 2
Hi Rick and Ghislaine,
I've deleted the post with the altered filter. I hope that now everything is okay again.
Regards,
Jane
I know this is none of my business, but I'm on a public forum. I can read people arguing even if I don't want to. It's very hard to unseen these arguments and dramas. And it's especially heart breaking and upsetting to see such interaction between known members!!!
I don't know what the heck happened with authorship above, it sounds like a technical mishap. It happens. This kind of conversation should be kept private via email.
I chose to comment on this thread because I've been here long enough to know both your personalities and names. It's an honor knowing people but it's difficult seeing people who I come to appreciate make such commentary as seen above. I hope arguments as such never arise again, but if it does, I hope people can be at least be respectful of one another and courteous in using appropriate language rather than the harsh, bold words being used here. These harsh comments CAN affect other people, even people who aren't involved.
This thread is sadly a clump of stress to me. I really just wanted to leave a comment, a couple suggestions and... instead I ended up reading stuff that I didn't want to. I'm sorry.
Filters: 712
Humm... I've just seen about my name appearing in the modification of your filter that Rick Duim did.
Maybe he worked on one of my filters before, so my name remained in his FF memory.
