Topographical Abstract by CFandM
http://www.filterforge.com/filters/13309.html
Thought I would post a sample of this...I took one of my macro photos and used this to test this version.... smile:) The original on the left and then the effect...
I like the filter, feels like glowing edges on steroids. I had one issue, don't know if it is something you can deal with. When I put a larger image into the filter, the topo lines do not get wider, so the larger the image the thinner the lines appear.
Well a couple of things with that...The way that I put this together it does not deal with being able to control the line width...It was more of simple quick method to create the lines....Here is the above image at a larger size....
Here is a larger image (reduced for the forum). Getting larger lines for a larger image (3200 pixels across) turned out to easy: Photoshop Diffuse (Lighten Only) 4 times did the trick.
The original. Notice the cheap editing towards the top to remove wires. I didn't bother cleaning it up knowing that abstract filters would do it for me smile;)
Cool this filter CF, it gives nice effects ! smile;)
xirja
Idididoll Forcabbage
With Anti-Aliasing and High Precision, its also very cool! smile:)
Thanks Ghislaine... smile:)
xirja..Yep its kinda neat as a start for a painty type of filter...
21 unregistered users.
